Thermo switch for cooling fan
  • element
    • Dec 2015
    • 288
    Ever since I have had this Marlin, every time I have driven it more than 1/2 a mile, the fan has switched on when I turn the engine off. Not such a bad thing and it certainly attracts attention when the fan is whirring away. There was probably a central top dial knob to adjust the thermo switch setting but it's long gone now. I just lived with it.
    However, a few weeks ago, on a sunny day I thought I'd go for a drive and when I turned the key there was nothing, no battery power whatsoever. Eventually I traced the problem to the fan switching on when I put it away in the garage & closed the door - but it had stayed on and flattened the battery. Since then this extended fan running time seems to have become more and more of a problem - so much so that I am now forced to unplug one of the wire leads at the back of the switch to manually disconnect it. Problem then is - I have to remember to reconnect the wire as otherwise the engine can overheat when going up big hills around here on hot days - unless I happen to see the water temp gauge!
    So basically I'm looking for a means of fixing the problem - or modifying the current thermo switch to switch on at a fixed temperature and switch off after either an adequately cooler one or else after a maximum time of maybe 10 minutes..
    What have you used / done to achieve a balanced system? This one looks to be set off by the fine copper pipe with an expanding tip that switches the electrical contact to on.. but it really needs replacing.
  • element
    • Dec 2015
    • 288
    Re: Thermo switch for cooling fan
    Supplying classic parts for Triumph, MG, Rover, Land Rover, Range Rover & Jaguar since 1982. Rimmer Bros offers OEM quality and trusted UK and global service.
    This looks very similar to mine.
      • 2790
      Might be worth a while with mole grip onto the "knob" and see if turning it into different positions has any different results?
      If the switch is working, shame to replace it, sourcing a knob should not be a problem
      • nigel_cordrey
        • Jul 2017
        • 89
        why can't you just rewire the switch to a ignition switch live. I've drilled and tapped a hole in the thermostat housing and fitted a radiator fan switch cambiare part number VE709047
          I used to have that setup but when the switch gave up I replaced it with this in the top hose. Been fine since. Switch was 95/85 one.
          Usually if the fan's running when I stop, which isn't very often, I let it tick over for a min. or two before shutting down.
          I also fitted an over ride switch so that when in traffic on a hot day I can cut it in. Also helps to keep the temp. under the bonnet down.
          • meverett
            • 662
            Thanks Hugh, that link will be helpful for me too as I am at that stage with the radiator.
            • scott h
              • Mar 2013
              • 670
              https://www.ebay.co.uk/itm/Stoney-Ra...tvdGmZ7G4jozFQ
              Car builder solutions have a similar in hose adapter which I used. The adjustable switches are too tempting to fiddle with all the time!
              Wire the fan through a relay with the earth going through the thermo switch. You can add a manual switch in an additional earth, so if either switch provides an earth then the fan will run.
