I am building a Cabrio with a Ford 2L DOHC EFI Late 1990 The car came with a Sierra loom and an Intermotor 15311 fits in the socket for the Electronic ignition Module as I think it should ? I have wired it in accordance with the Haynes manual which shows a four wire connection as per the plug on the loom there are however I note six pins on the E I M I am getting no power to the coil and in consequence none to the LT side of the engine management relay
I wondered if anyone had any ideas In other words H E L P!! Thank you Nigel
