I hope this might be useful to compare ratios. My car, Millie, is based on a 2litre Ford Sierra with a Pinto engine, type 9 gearbox and 3.62 differential. The engine has been replaced with a 2L Zetec.
Millie as she is 3.62 diff
This is the standard 2L Sierra Pinto engine with type 9 gearbox with 195/ 65 R15 wheels. The original Sierra donor had 185/70 R13 Wheels and tyres (195/60 R14 are virtually the same). The larger wheels on Mille mean slightly less acceleration. At 70mph in 5th is about 3,000 rpm in the Sierra it would require 3,200 rpm. The difference is more than compensated by a lighter car.
Millie with 3.9:1 Diff
This diff compensates for the larger wheels 70mph is again at about 3,200 rpm.
A useful way to see the data is what rpm is needed for a given speed (3.62 diff).
With the 3.62 diff 30mph is a comfortable 1,600 rpm in fourth and 70mph 3,000 rpm in fifth.
I would be interested to see which diff ratios and gearboxes others have used. I would particularly like to know how happy they are with the result.
Code:
[B]Engine rpm Gear Ratio 1000 2000 3000 4000 5000 6000 6500 7000 Gear 1st[/B] [COLOR="#808080"]3.656[/COLOR] 5.3 10.5 15.8 21 26.3 31.6 34.2 36.8 [B]Gear 2nd[/B] [COLOR="#808080"]1.97[/COLOR] 9.8 19.5 29.3 39.1 48.8 58.6 63.5 68.3 [B]Gear 3rd[/B] [COLOR="#808080"]1.37[/COLOR] 14 28.1 42.1 56.2 70.2 84.2 91.3 98.3 [B]Gear 4th[/B] [COLOR="#808080"]1[/COLOR] 19.2 38.5 57.7 76.9 96.2 115.4 125 134.6 [B]Gear 5th[/B] [COLOR="#808080"]0.82[/COLOR] 23.5 46.9 70.4 93.8 117.3 140.7 152.5 164.2
Code:
[B]Gear 1st[/B] [COLOR="#808080"]3.656[/COLOR] 4.9 9.8 14.7 19.5 24.4 29.3 31.7 34.2 [B]Gear 2nd[/B] [COLOR="#808080"]1.97[/COLOR] 9.1 18.1 27.2 36.3 45.3 54.4 58.9 63.4 [B]Gear 3rd[/B] [COLOR="#808080"]1.37[/COLOR] 13 26.1 39.1 52.1 65.2 78.2 84.7 91.2 [B]Gear 4th[/B] [COLOR="#808080"]1[/COLOR] 17.9 35.7 53.6 71.4 89.3 107.1 116.1 125 [B]Gear 5th[/B] [COLOR="#808080"]0.82[/COLOR] 21.8 43.5 65.3 87.1 108.9 130.6 141.5 152.4
Code:
[B] RPM 1000's[/B] [B]Speed mph 20 30 40 50 60 70 80 90 [/B] [B]Gear 1st[/B] 3.8 [B]Gear 2nd[/B] 2.0 3.1 4.1 [B]Gear 3rd[/B] 1.4 2.1 2.8 3.6 4.3 [B]Gear 4th[/B] [COLOR="#FF0000"][B]1.6[/B][/COLOR] 2.1 2.6 3.1 3.6 4.2 4.7 [B]Gear 5th[/B] 1.3 1.7 2.1 2.6 [COLOR="#FF0000"][B]3.0[/B][/COLOR] 3.4 3.8
