Waterless coolant
  • B_Cocks
    • 2
    Waterless coolant
    Hi all not sure whether this has been a topic on the forum before. But I wondered if any one had any experience on the waterless coolant available from a company called "Evans" I have read the specs ect and just wanted to find out more about it before shelling out £150 for coolant and cleaner liquid. I run a Ford 2.9 v6 dated from 1987. Any comments gratefully received
    Barry
    Re: Waterless coolant
    The closest I got was https://www.marlinownersclub.com/for...ight=Waterless
    But, if you have an overheating problem, surely it’s best to identify the cause, before researching, for a solution that may be an unnecessary expense. Poor ignition timing, dirty/contaminated water system, poor airflow, etc etc etc.
    It appears to me that it’s mostly an aero engine problem. Very different from a road car, and far more operation critical.
    Rather like F1 filling their tyres with nitrogen, becoming a racing norm, but to relate that to a road going car already using air at 78% nitrogen in natural air, it seems absurd to me.
    How do you purge a tyre of every drop of air N2+ O2 + tiny percentages of other gasses, because you can’t draw it down to a vacuum without pulling the tyre off the bead.
