Engine number ?
  • marlin1984
    • Jul 2019
    • 62
    Engine number ?
    I freely admit to being puzzled by the engine number of my 'new' Marlin Roadster.
    I was told it was an MGB engine BUT the number on the alloy plate does not seem to fit.
    [Block casting has 1800 on it.] Twin carbs are SUs from an MGB.
    Aluminium plate is embossed [from underside ?] with number '486733 ER550**' , held down by 2 drive-rivets in typical Leyland fashion, and has AD externally stamped later below it.
    AD may possibly stand for Autosprint Developments [who used to tune B-series] ?
    (there is a scribbled note with the car that says it has an Autosprint Developments big-valve head ...)
    Was expecting a number beginning 18V ...
    ETA ** represent numbers.
    Re: Engine number ?
    A photo of the plate in question would help.
    B series blocks were used in numerous vehicles and were frequently swapped around, particularly Marina engines being transplanted into MGB’s as the cranks were perceived to be better.
    There is also a common misconception that every B series 1800 is in fact an MGB engine.
    There are many differences, from 3 to 5 bearing crankshafts, to exhaust manifolds, ancillaries, to the engine back plates, starter motors,, clutch, flywheel, etc etc.
    Through history, with numerous personal inputs, it’s difficult to tell whether the engine number actually relates to what you really have. The block may well be Marina, but the head could be MGB, or even Land Crab in origin, let alone all the other BL/MG marques that used basic B Series block.
    You could well have a bitza engine, that people call for convenience an MGB engine, even though the complete ensemble of parts from fan at the front to flywheel and clutch at the back, does not conform to a single identifiable defined vehicle.
    • marlin1984
      • Jul 2019
      • 62
      Re: Engine number ?
      Thanks for that Steve. Will try and take a picture tomorrow - weather permitting.
      [Have removed the metal fan already as too far from rad to have any effect. There is a Kenlowe fitted.]
      • marlin1984
        • Jul 2019
        • 62
        Re: Engine number ?
        Looking closely at an enlargement of the picture I took - I reckon the third digit is NOT a 6 - but rather more likely a G.
        Still not sure if that helps tie down the origin of the block ...
        It may help - because 48G733 engines were apparently Gold Seal MGB engines - so maybe I will be telling DVLA.
          • 709
          Re: Engine number ?
          This page might help if you haven't seen it already (lots of other good stuff in there too)...confirms that 48G733 is a Gold Seal replacement for an 18V MGB engine. Lots of MGB forums out there and this question seems to crop up quite frequently.
            Re: Engine number ?
            Originally posted by marlin1984 View Post
            Looking closely at the picture I took - I reckon the third digit is NOT a 6 but more likely a G.
            It may help - because 48G733 engines were apparently Gold Seal engines - so maybe I will be telling DVLA.
            The numbers after 48G were a code for the bore size etc.
            I don’t see a picture!
            • marlin1984
              • Jul 2019
              • 62
              Re: Engine number ?
              Hi Steve.
              No photo yet ... I'm still trying to edit via Flickr. But it keeps on saying I'm using an 'unsupported browser' and inviting me to download the latest version of Google Chrome.
              Done that but still asks again and again and again.
              I'll sort it.
              ETA [ 19/09] Given up on Flickr.
              • marlin1984
                • Jul 2019
                • 62
                Re: Engine number ?
                Very interesting page. Thanks.
                One entry I simply don't understand > "February 2010: In practice Gold Seal engines have an 'E' or 'N' suffix letter as in 48G733E nnnnnn. The 'E' refers to an exchange engine, either fitted by a dealer or an owner. 'N' refers to an outright purchase i.e. no return of a faulty unit. "
                Seems like a dogmatic statement of fact . Perhaps it should read "In practice some Gold Seal engines have an 'E' or 'N' suffix ...." ?
                In practice - mine does NOT. It has neither 'E' nor 'N'.
                It does have a PREFIX to the engine number but definitely NO 'suffix letter after 48G733'.
                Seems even 'experts' can get it very wrong!
