IVA Vin Number
  • NigelBush
    • Aug 2015
    • 42
    IVA Vin Number
    I note that the IVA Requires the vin number to be on the right hand side of the car . Marlin have constructed my Cabrio with the stamped vin number on the left hand side . I wonder if anyone has had a similar problem and what the reaction from the inspector was to this ??
    Many thanks
    Nigel
    Re: IVA Vin Number
    I had the same issue. Mine failed IVA because of this ( and a few other minor issues though it was the first Cabrio to get throught IVA)...
    I bought a set of number/letter stamps and stamped the VIN number on the top of the RH scuttle.
    The IVA inspector was happy with this and commented it was a stupid requirement.
    My other major issues we to do with radius/sharp edges. Mostly cured by putting U section rubber around the whole of the mudguards, runningboard/wings and visible bolt heads in the front suspension. Also over the nuts on the steering arms.
    Don't forget to do the lower edge of the dashboard and any possible sharpe edges like heater controls, even under the dashboard
    • NigelBush
      • Aug 2015
      • 42
      Re: IVA Vin Number
      Thank you very much for your reply Did yo use U section on the nuts on the steering arm
        Re: IVA Vin Number
        For the standard nuts I bought some rubber nut covers that just slip on.
        On the anti-rollbar where the large nuts is on the end I made a cover from some water pipe insulating foam and covered it in gaffer tape, then glued it in place.
        On the steering arm adjustment nuts I covered them in concertina plastic tube with cable tie to hold them in place
          Re: IVA Vin Number
          I ground the VIN plate welds off and rewelded the plate on the opposite side
            Re: IVA Vin Number
            Mike, my VIN was split over 2 lines which was not considered acceptable
            • NigelBush
              • Aug 2015
              • 42
              Re: IVA Vin Number
              Thank you my plate is on two lines so definitely not allowed by the sound of it
              • NigelBush
                • Aug 2015
                • 42
                Re: IVA Vin Number
                Once again thank you Looks like a busy week ahead !!
                N
