Can anybody tell me if there is enough clearance to use a Momo 350mm (14 inch)wheel on the LWB Cabrio. I know Marlin recomend the a 325mm (13 inch) wheel but I would like to use the bigger wheel if possible for the benifit of steering weight. I am using the Marlin door panel with the elbow cut out.
Steering Wheel 325 or 350 mm
Re: Steering Wheel 325 or 350 mm
Message originally posted by: Doug Billings
I have a 14" steering wheel on a SWB Cabrio without door cutouts
Standard Sierra wheel is 15" and it works, so a 14 inch should be ok. What front tyres do you run, and at what pressure. What is you front axle weight. I have ordered a 13" motalita, as I found the std wheel rather indirect, and quite light.(450kgs front, 195/65 tyres.)???
