Gps tracker
  • mike woodley
    • 121
    Gps tracker
    Hi
    has anyone installed a GPS Tracker for security purposes? I am considering installing one on my Cabrio. The thinking is that If my pride and joy was stolen, then i assume i would know its location. I found this which looks ideal https://www.rewiresecurity.co.uk/db2...iy-gps-tracker
    Any advice appreciated.
    Mike W.
  • meverett
    • 662
    Re: Gps tracker
    Looks good and excellent reviews but as it uses a mobile network with their pre-programmed sim what are the PAYG costs?
    I had a quick glance through.
    Great idea and if the PAYG is cheap enough be good to install on all cars.
      Re: Gps tracker
      PAYG costs are as confusing as the telco’s can make it. I bought a SIM for £1 and topped it up with the minimum £10 credit. I used this in my tracker. It worked! I do not use the car that much so I did not use much of the credit on the SIM. I think the credit expired after six months. The SIM’s phone number got recycled shortly thereafter so that SIM will need to be replaced.
      Touch wood there is very little value in recycled cars so I decided renewing the SIM wasn’t worth the effort (fingers crossed).
        Re: Gps tracker
        Ok, I know i'm not uk based , but Free here do a sim for 2€ per month, 2hrs calls and unlimited sms. its essentially aimed at kids who use sms all the time here a la frog!
        • mike woodley
          • 121
          Re: Gps tracker
          Hi,
          The sim with the GPS Tracker has an annual top up of £60. Sounds a lot but for peace of mind its only £1.20 a week. I will just cut out half of lager a week to pay for it!
          • stevepritch
            • Sep 2017
            • 290
            Re: Gps tracker
            Originally posted by mike woodley View Post
            Hi,
            I wonder if the company would offer discounts to the owners club if a number showed interest? £5 a month is not a lot anyway.
            • 928cdu
              • 230
              Re: Gps tracker
              Hi all .. a little more heath Robinson approach is to use an old iPhone hidden .. in the case of my BM, it’s under the boot floor .
              Old iPhones can be got quite cheaply if you’re not concerned about spec or you may have one around anyway .Just wipe the phone and setup a dummy profile, the share location with your own phone. ‘Find friends’ app.. Cost again is £5 per month.. but you have a spare phone to use in emergencies as a bonus.
              Several guides exist on YouTube to do the above..
                Re: Gps tracker
                The charge adaptor may be a bit of a trail to the phone.
                Otherwise a neat idea provided you set up a regular DD to top it up.
