Sportster steering rack
This topic is closed.
  • dunny321
    • Sep 2019
    • 2
    Hello to all and season’s greetings.
    Please could someone advise me.
    Due to rust I am thinking about fitting a new steering rack, but I understand that the rack on a Sportster was specially made for the model, so a standard Sierra rack would be different. Please could anyone tell me what the difference is and could I make a standard rack fit. Thanks in advance. Steve.
  • copperleaves11
    • 328
    Re: Sportster steering rack
    Hi Steve. I managed to adapt a standard Sierra rack to fit.The outer case needs to be shortened and sleeved and the main rack itself needs shortening also. From memory the Sportster rack has a 20mm dia bar and the Sierra is 25mm. My contact number is in Pitstop (Peak District meet) should you require more info.Regards David
    • dunny321
      • Sep 2019
      • 2
      Hello David,
      Thanks for your reply, now I have an idea of the alteration required I think that would be beyond my abilities. For now I will clean up the case fit new track rods, track rod ends and gaiters and refit. It works ok but could look better. Regards Steve.
