speedometre 1800 marina
  • kolmershlagjp
    • Dec 2015
    • 180
    bonjour
    is the connection of a speedometer of a 1300 marina compatible with a speedometer of 18000 marina
    what is the difference in pinout
    Re: speedometre 1800 marina
    My understanding is that the speedo cables for the standard 1.3 and 1.8 are identical.
    i mis read your post. I have no knowledge of the specific wiring, but the parts books suggest they are the same.
    • kolmershlagjp
      • Dec 2015
      • 180
      bonjour
      is the electrical connection identical from 1300 to 1800 ?
      I see an additional connection
      merci
      • john cole77
        • 22
        I think that the additional connection that goes to the red wire linking to the Tachometer is a 12v feed from the ignition.
        • boustrophedon
          • Apr 2019
          • 89
          Wiring one of those up really requires the original plug, then you can refer to the colour codes in the wiring diagrams.
            Originally posted by kolmershlagjp View Post
            bonjour
            Looking at the track pattern of your two pictures, they are remarkably similar. I would say the pinouts are identical.
            • john cole77
              • 22
              This thread from the fast marina magazine addresses the issue of changing a 2 dial unit for a 3 dial unit. The only differences appear to be the additional wiring for the Tachometer.
