Fuel tank
  • trevor_ford
    • 213
    Fuel tank
    Can't find my instruction manual and I need a new fuel tank. Can anyone remember the tank used in a 1984 Mk2 Roadster? Escort van? Attached picture shows what happens when you decide to rebuild after 22 years!
    Re: Fuel tank
    Hi Trevor (your pic didnt stick) either escort Mk1 or Mk2 Van or Estate tank or if your feeling flush you could get a bespoke one built.
    • trevor_ford
      • 213
      Re: Fuel tank
      Thanks Ben. Just changed photo - bit too big the first time. Thanks for the info. Now to find one.
      • trevor_ford
        • 213
        Re: Fuel tank
        Still too big - try again.
        • rob
          • 11
          Re: Fuel tank
          Hi Trevor,
          Good picture. Just out of interest, what motor is that? I can see a SOHC and an SU carb?
            Re: Fuel tank
            Judging by the length of it that doesn't look like a standard tank???? How about a pic.from the rear?
            • trevor_ford
              • 213
              Re: Fuel tank
              I seemed to remember it was an Esort tank as confirmed by Ben. The filler was modified from horizontal to vertical. The motor is a 1.7 Ital.
                Re: Fuel tank
                Message originally posted by: Hugh
                Now I can see it better it is as recommended in the manual, Escort Van or Estate Mk. 1 or 2
