Brake parts.
  • yousay54
    • Aug 2018
    • 90
    Brake parts.
    Hi checking the brakes on my Roadster took the rear drums off clean out with brake cleaner brilliant stuff, what I need I the small screws that hold the brake drum on only found 1 one 1 side none on other side, can anyone tell me what size they are please, had a quick look on Ebay, for a Marina axle thanks, Ray.
    Re: Brake parts.
    Try Rimmer Bros or other Triumph specialists. Marina axle is Triumph-derived.
    Order your Brake Drum Screw 1/4 UNF x 3/8" - V5435 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
    • boustrophedon
      • Apr 2019
      • 89
      Re: Brake parts.
      Why? They don't do anything, The drums are held on by the wheel and four big studs, it's not like they can fall off.
      • yousay54
        • Aug 2018
        • 90
        Re: Brake parts.
        Hi thanks, but like to be right stops the drum from moving, thanks for replys.
        • philcoyle
          • 379
          Re: Brake parts.
          Hi You,if you don't have any joy drop me your address in my private message box and I'll sort it. about 13mm by 6mm counter sunk.
          Phil
          • yousay54
            • Aug 2018
            • 90
            Re: Brake parts.
            Hi Phil thanks for the help may take you up on the offer will sort to pm you, thanks Ray.
              Re: Brake parts.
              I fit them if I've got them otherwise, not. The big thing is if you lose a wheel the drum gives you brakes if it is still in place! Also, it rolls instead of digging in. Or so I'm told. I hope I never have personal experience of it!
                Re: Brake parts.
                Phil
                they are certainly not metric.
                  Re: Brake parts.
                  Beware standard countersunk screws. Their heads are larger than the ones used by BL.
                  The result can be, though you have torqued up all four wheel nuts the wheel is not clamped face to face with the hub, but only partially clamped leaving a gap between the wheel and hub, where the overlarge screw head is.
                  If you are using alloys, the screw head will gradually eat into the alloy until you have a distinctly wobbly wheel that could easily result in snapped studs and consequent catastrophic incidents.
                  If in doubt buy from Rimmer.
                  • yousay54
                    • Aug 2018
                    • 90
                    Re: Brake parts.
                    Thanks have alloy wheels, and will buy from Rimmer.
                      Re: Brake parts.
                      I will give Darren Groves the credit for this info not tried it myself but quite a few Triumph owners have done this upgrade.
                      OOPs wrong thread see for sale section below.
                        Re: Brake parts.
                        Originally posted by b_caswell View Post
                        http://www.tssc-devon.org.uk/technic...d-upgrade.html
                        There are tools that let you delete your own post!
                        • yousay54
                          • Aug 2018
                          • 90
                          Re: Brake parts.
                          Hi just want to say thanks very much to Philcoyle who sent me first class post the screws I needed for my rear brakes, brilliant and thanks he wont tell me how much cost is, some very helpful people on here, thanks again.
                          • philcoyle
                            • 379
                            Re: Brake parts.
                            You're welcome to the screws, whilst working at Morgan Motors they were changing the Dacromet screws to stainless steel and the dacromet were scrapped . I could not let such a special coated screw get binned so I asked Steve Morris MD if I could have some, " help yourself" so I did. So I cant charge you for something I got for nothing , just helping another Marlineer simple as that.
                            • yousay54
                              • Aug 2018
                              • 90
                              Re: Brake parts.
                              Thanks very for your kind offer you should be proud of yourself, would do the same if I could help anyone, thanks again.
