Door handles
  • beergutdave
    • 47
    Door handles
    Hi
    what is the best type/way of fitting door handles.
  • f.swaans
    • 21
    Re: Door handles
    Hi, i have the same problem and i will fixed it with drive-in nuts for wood or spot weld nuts.
      Re: Door handles
      This all depends on if your having to comply with current SVA regulations. The SVA requires a two stage release system and the latest roadsters (YKC and Aquilla) had a special lock. Otherwise a standard mortice latch in the door with a classic door handle works. You then mount a striker plate on the body return as per original build manual.
      • cdow
        • 224
        Re: Door handles
        Just looking for locking handles (as mine sometimes fly open), and found these on ebay - they look like direct replacements for the ones commonly fitted and cheaper than CBS, Europa etc.
          Re: Door handles
          Below are the originals that were supplied by Marlin.
          As you can see the handle shaft needs cutting down to size and the lock has three threaded nuts welded on as the lock is only supposed to attach in three places.
          A picture of the strike plate is also included.
          I will scan the section out of the manual so you can see how they all go together.
          As stated these are all standed except for the Marlin welded nuts.
          • hipster65
            • Jan 2012
            • 9
            Re: Door handles
            when i saw the heading on this thread, i thought it was going to be a 2 ronnies scetch, how disappointing....
              Re: Door handles
              I wonder if we could start a thread about O's
                Re: Door handles
                Is that garden o's or fire o's
                • terryreed1664
                  • 257
                  Re: Door handles
                  Very good Ben, LOL
