Berlinetta project
    • 1226
    Berlinetta project
    I may consider (lifting out) the complete Zetec package if someone wishes to up grade their own Berlinetta. This is the full package that was supplied by YKC which includes Zetec engine, Griffin Manifold, Racetech water rail, Omex 6oo and Omex engine loom with instructions, starter alternator and bracket and starter motor. Then there is a branch manifold and side exhaust if reqd all in stainless. Danny 07976836374 or [email protected]
  • philmcgrath
    • May 2015
    • 89
    Re: Berlinetta project
    Would this package work in a Cabrio which currently has the Ford 2.0 DOHC EFi engine and MT75 gearbox?
      Yes. I replaced a dead DOHC carb engine with a Zetec engine from Omex, along with their Omex 600 ECU. I detailed it in https://www.marlinownersclub.com/for...an-engine-swap .
      If Danny is selling the complete package it should not be too difficult. Bits I needed outside help with was fabricating the engine mounts, but if Danny is removing the package it should come with those. Apart from that I had a stainless exhaust system made up. Otherwise the work was spanners, wiring and plumbing.
        • 1226
        exactly as Chris says Yes it will.
        • wiggiesworld
          • 402
          Interesting Danny, I think I will join the queue after Phil.........
