Nice touch
  • jon202
    • Oct 2020
    • 38
    Nice touch
    Engraved clocks
    Re: Nice touch
    1200 rpm and zero oil pressure, would worry me, even if the gauges look nice!
      Re: Nice touch
      Just shows that you can look and not see. My cursory glance had failed to notice the engine was running!
      • jon202
        • Oct 2020
        • 38
        Re: Nice touch
        Engine not running the rev counter sticks when not running but when running works normal
        • ggrum
          • 782
          Re: Nice touch
          When I had that particular rev counter fitted it did exactly the same, i.e. stayed at idle revs when you switched off. If you briefly switched the ignition back on the rev counter would then drop to zero. I mentioned it to a friend a while back who had just bought a brand new Morgan with the same instruments fitted and it did exactly the same thing. Recently I changed to Smiths instruments and no longer have that problem, not that it was really a problem anyway.
          • Kahawi
            • Jan 2018
            • 159
            Re: Nice touch
            Exactly the same with my Hunter, (and that make of rev-counter), needle stays at whatever revs the engine is at, when the ign is turned off.
            Not really a problem in practice, as said if needed a flick on-off will zero it, OCD I have, but not that bad!
            • jon202
              • Oct 2020
              • 38
              Re: Nice touch
              Yes it doesn't bother me as it reads normal when engine running but may change all the gauges to Smith's one day
              • Ye Ol Ripper
                • May 2016
                • 297
                Re: Nice touch
                I bet that engine will keep ticking over at that idle speed whilst using no fuel at all indefinitely and also will be totally silent too .Wow the ultimate eco friendly Marlin
