I will be fitting new dampers as part of my restoration as the originals are at least 30 years old!
As I understand it you fit Marina dampers to the rear but Triumph Herald rear dampers to the front as they incorporate bump stops.
In the past I have always fitted adjustable dampers on my projects but there doesn't seem to be a great deal of choice for the Marina rears. So far I have only found Spax which are fairly expensive at around £100 per corner.
So my question is - what have others used? I guess some other owners must have replaced them sometime in the recent past?
Cheers, Robin
Cheers, Robin
