Ignition and door lock
    I noticed that my Cabrio’s ignition lock was very worn so got a refurbed set (ignition and door) from an eBay’er, a chance to get one key for both as well.
    Managed to fit the ignition barrel OK but gave up with the door lock as it meant fumbling around with the window winder and door handle which I could see was going to be less than trivial.
    So partial success, I now have a good ignition lock and key so no more worrying about the thing jamming up on me, but for now at least still need another key for the door lock.
    While looking at the door I noticed the restraining strap bracket is starting to pull out of the panel, pic attached. Maybe worth checking your own for similar wear and tear.
  • wiggiesworld
    • 402
    Re: Ignition and door lock
    Well why not expand the task and convert to electric windows whilst there?
    Must admit I will be off to look at the strap attachment of my doors and that doesn't look too good. It would have made sense to fit a flat plate inside the door for it to bolt up to so as to spread the load.
      I put a plate behind the bracket to spread the load.
      I don't bother with door locks, mostly I have the roof off anyway so it doesn't make sense, and it is probably easy enough to get into the car with the roof up.
        The only difficulty I recall with the earlier Cabrio's is the window winder mechanism is attached to the trim panel, later cars with the sculptured trim have a sub panel behind the main one to which the mechanism is attached so making the removal / refitting a lot easier. It's not that bad a job and what else can you do at Christmas !
          I found this, being an earlier car, out the hard way. I’ll get back to it when the weather warms up and I can get the car on the drive so it’s easier to work on.
