Roadster Heater
  • marlinmick
    • Mar 2020
    • 81
    Roadster Heater
    Hi All
    I'm in the process og refurbishing my Roadster 1.8 TC Marina based. I have been trying to get my Heater Matrix re-cored its not leaking but at 40 odd years old I like to change it while its out. Its the Marlin Supplied Heater Box that has the standard Marina Matrix fitted. I have tried a couple of local radiator co. but apparently that type of core is no longer available. I could have a new matrix made in Alloy but at £250.00p I'd sooner do without the heater. Anyone got any ideas for a suitable replacement?
    Mick.
  • duncan
    • Apr 2018
    • 137
    Re: Roadster Heater
    Have you had a look at oil coolers? they are about the right size and there are lots available
    • scott h
      • Mar 2013
      • 670
      Re: Roadster Heater
      What about this on ebay?
        • 2447
        Re: Roadster Heater
        I have one of these fitted, punches well above its weight and size.
        https://www.t7design.co.uk/2-2kw-mic...9-cc4-d35.html
        • AndrewKB
          • 124
          Re: Roadster Heater
          I've got the heater matrix + box + fan that came out of my car during the rebuild. Free to collector. I'll take a photo and post it here within 24 hours.
          • marlinmick
            • Mar 2020
            • 81
            Re: Roadster Heater
            Thanks for the info I've not looked at Oil Coolers but its a good option that I'll give some consideration to!
            • marlinmick
              • Mar 2020
              • 81
              Re: Roadster Heater
              Yes I spotted the NOS Heater Elements on ebay but what puts me off is that although not used they are still about 40 years old, I think the last Ital was about 1980 unless these have been made since. What concerns me is that if they are Genuine NOS Items they could still contain the soldering acids/fluxes during their long term storage so could the metal be eroded and cause them to fail under pressure. I have brought lots of NOS parts for Japanese bike restorations and sometimes I wish I'd not bothered.
              Thank you for your input anyway.
              Mick.
              • marlinmick
                • Mar 2020
                • 81
                Re: Roadster Heater
                Hi Adrian, this heater looks quite good and it will be definitely worth looking at I'll take some measurements, have you got any pics of it in situ in your Roadster. I originally made my Marlin Supplied Heater Box to blow warm air up to the screen through Morris Minor Demister Component's and I'd like to keep this feature as it does demist the screen with the Hood up, hence the reason I'd like to see this compact heater in situ.
                Thank you for the information.
                Mick.
                • marlinmick
                  • Mar 2020
                  • 81
                  Re: Roadster Heater
                  Andrew, I would e very interested in having that Heater Assembly off you as it would give me another option outlet along with the other member suggestions. Obviously during the present restrictions I would not be able to travel to you to collect it, but as soon as the restrictions are lifted maybe we can come to some agreement for me to come and collect it. I'm in Derby and I see that your in Cheltenham so I would be happy to nip down to you to collect it, it would give my Cabrio a run out as well.
                  Alternatively I might even be passing through your area in June/July going to Newton Abbott in Devon for 3 weeks holiday towing a caravan (not with a Marlin I hasten to add) if we are allowed, so maybe you could meet me at a motorway service area with the heater, we usually stop for a break at the new Gloucester Services for a hour.
                  Kind regards and thank you for your offer.
                  Mick.
                  • Ye Ol Ripper
                    • May 2016
                    • 297
                    Re: Roadster Heater
                    With regards to Heater matrix's for the benefit of us all. Does anyone know if the classic mini heater matrix could be/ had been used in the past ?
                    Here's what they look like and if it could be made to fit, I would imagine the heat output would be sufficient for a Roadster with the soft top and side screens fitted.
                    The heart of your heater is the radiator matrix which often gets overlooked when cleaning the cooling system. They often get clogged and cannot be cleaned rendering your heater useless. Replacement is the only answer if flushing out does not clean it suff
                      Re: Roadster Heater
                      Have a look at Car Builders Solutions. No connections, just a happy customer.
                      • AndrewKB
                        • 124
                        Re: Roadster Heater
                        Mick - I've just had a look in the garage and the heater assembly is not where I thought it was. I'll let you know if I find it ;-)
                        • marlinmick
                          • Mar 2020
                          • 81
                          Re: Roadster Heater
                          I've looked at several different heater elements and I think that lots of them could be made to fit if you cut and shut the Bulkhead which is not something I want to do. It I could start with a new Bulkhead I'd make the centre section so that it could be lifted out of the engine bay complete with the heater assembly attached. If I had access to a folding machine then I would definitely make a New Bulkhead and start from scratch.
                          Mick.
                          • marlinmick
                            • Mar 2020
                            • 81
                            Re: Roadster Heater
                            CBS are good I use them quite a lot, little bit pricey but at least they have the stuff.
                            • marlinmick
                              • Mar 2020
                              • 81
                              Re: Roadster Heater
                              No Problem Andrew I'm always losing stuff.
