Bluebelle is stuttering slightly on 'high G turns', just made myself laugh there.
Worst is turning left pulling away up hill, which is why I am thinking tank surge. I've not run it on more than half a tank, I suppose I should fill it up and see if it stops, which would indicate field surge in the tank.
So looking into that before finding some to pull the carb apart to check the float(s) levels.
Doug: Did you see this at all when you had the car. It's not too annoying, so don't want to spend a lot of time on it if it's something you lived with as well.
