The matrix
  • jon202
    • Oct 2020
    • 38
    The matrix
    Hi peeps
    I have a cabrio with 2.8 v6 cologne engine and the rest is ford Sierra based.
    I need to change my heater matrix can anyone guide me on this as i can only see the way to get it out is to remove the pedals is this the only way
    Re: The matrix
    That's how I've done it in the past - otherwise it's a dash out job. Once pedals are out of way it's a cinch but do give yourself plenty of room and take out seat and steering wheel.
    • jon202
      • Oct 2020
      • 38
      Re: The matrix
      Thank you I'll be tackling it this week at some point
      • lizbillings
        • 828
        Re: The matrix
        I removed centre console and dashboard after which you can remove the whole heater unit. Not tried getting just the matrix out. Doug
        • djj_engineer
          • 405
          Re: The matrix
          I remember when I built FMB the heater was the first thing that went in!! I remember thinking I bet that is a swine to get out.
          • jon202
            • Oct 2020
            • 38
            Re: The matrix
            I have been told it can be done by removing the steering colum and open a bleed nipple on the brakes yo allow the brake peddle to be press down to the floor also press clutch pedal down and the matrix will just about come out.
