Help needed to identify the fuel tank in my roadster
  • siliconman
    • Jun 2020
    • 8
    Hi
    I am trying to identify the fuel tank currently in my Marina based Roadster. I believe it should be a Mk1/2 escort estate, but looking at pictures on line and in the build manual it doesn’t look the same.
    hopefully someone can identify it.
    Thanks
    • 929
    Re: Help needed to identify the fuel tank in my roadster
    That looks like a custom tank to me
      That’s what I was thinking, similar to the one I had made for PKK.
        Custom tank, not a Ford standard.
        • siliconman
          • Jun 2020
          • 8
          Thanks guys or should I say tanks, I thought it looked special, I guess I will need to get another made. Anyone know a good supplier, I don’t want an aluminium one as I trial so it need to be steel. I’m in Gloucestershire so anywhere near would be good.
          • getafix
            • 34
            Is there something wrong with the tank? Can it not be repaired?
            • siliconman
              • Jun 2020
              • 8
              It’s got some rust on the hangers but the main problem is a big dent in the bottom, which may be possible to correct through the gauge hole. I would also like a gauge that works fitted
                Now you want the fuel gauges thread. I cut the sender out of a Marina sender and silver soldered it to the ford pipe. Bending the float wire to suit. It reads right FSD empty to full.
                  • 2792
                  P M sent...look top right under "Notifications"
                  Rgds DC
                  • dave_clutterbuck
                    • Jun 2012
                    • 260
                    I have had a couple of tanks repaired over the years by Cropper & Jones 0151 356 0159 may not be ideal for you as they are in Ellesmere Port
                      • 1235
                      I have a very good Ford escort estate/ van tank, and I am located near junction 4 of the M5.
                      • marlinmick
                        • Mar 2020
                        • 81
                        I made my tank myself when I build my Roadster in 1985. I based its dimensions around the original marine Sender. I fabricated it out of 16 gauge mild steel sheet using heavy duty angle and a large engineers vice to form the bends. It was seam welded by a welder at work using the then ubiquitous packet of fags economy, cost me 20 Bensons. I pressure tested it at 5 psi which blew the welding deformity out of the tank top surface. Capacity is about 7 Gallons.
                        Regards to All.
                        Mick
                        • AndrewKB
                          • 124
                          Apologies that I don't check the Forum more frequently. The tank in the first pictures is almost certainly a 'Steve Holder Special'. I have recently replaced mine with an aluminium copy. If you want more info please email [email protected]. I am in Cheltenham so you're welcome to come and view my car.
                            By the way, D.W.Classic spares (Liverpool) have an Escort Mk1-2 fuel tank on eBay £39.99 07435966844 no connection just happy customer.
