Hi again.
I'm really struggling with the front wheel hub carriers identification fitted to my Cabrio. I have seen some new old stock ones on ebay, but at £60 each don't really want to risk it. The items fitted at the moment carry the Ford code B3 170 AH for right and B3 171 AH for the left, they do not have the ABS probe drilling.
The ones on ebay and every other bit of info I can find says the early Seirra carrier code should be B3 170 AG. All the info I've seen shows these with the ABS probe drilling. The dimension I think is different to the ones on ebay is the distance between the centre of the lower ball joint and the track rod end centre which I have tried to show on my picture. Mine have a dimension of approx 130mm.
Drawings and info I've found seem to point to the B3 170 AG arm having a dimension of approx 120mm. They may well fit but I'm thinking the steering would be heavier as the distance to the track rod end would be less.
Would anybody be kind enough to measure there carriers. Additionally if you could find the code cast into the arm, that would be very useful.
Any help appreciated Thanks Phil
