Cabrio front Wishbone Brackets
  • mike woodley
    • 121
    Hi,
    I need a pair of Cabrio front wishbone mounting brackets, wishbone pivot brackets, due to stress fractures.
    Will have some made if none available.
    Any advice appreciated. Regards Mike.
    • 1644
    Re: Cabrio front Wishbone Brackets
    Originally posted by mike woodley View Post
    Hi,
    I suggest as a precaution you replace all four while you are at it. Make sure that the bolts are no longer than existing or you wont get the nuts on! Namrick in Hove will stock the correct grade of bolts. They will need a small tack weld either side of the head as there is no room to get a spanner in there. Peter.
