Proximity of handbrake cable to rear dampers
  • martinclan56
    • Feb 2020
    • 486
    I have just trial fitted the rear axle, and all the associated bits and pieces, to my Marina based Roadster. My goodness it's heavy!
    I am a bit concerned with how close the handbrake cable is to the dampers. It seems to be worse on the drivers side with a clearance of only 1 or 2 mm. I think it could easily touch when the car is being driven - which I guess would be an MOT failure.
    Is this a standard problem and, if so, what have others done about it? In a worse case scenario I suppose I could extend the hand brake levers (the ones that pass through the brake back plate) by a few mm but that would be a real pain to do.
    The picture was taken with the handbrake cable slack, but even with it under tension, the situation doesn't improve significantly.
    Cheers, Robin
    PS - I am using Spax adjustables - perhaps they are slightly bigger in diameter than OEM dampers?
    hand brake cable by Robin Martin, on Flickr
    axle trial fit by Robin Martin, on Flickr
    Re: Proximity of handbrake cable to rear dampers
    Seem to recall mine was very much the same when I built it, never caused any issues in the 12 years I had the Roadster.
      • 686
      Mine's the same with standard dampers. As dogoncrazy says, not caused any issues and MOT inspector has not mentioned it over the years.
        • 2797
        Normal I believe, this was Q67 during rebuild.
        Robin you might like to think about reversing the top shocker bolts, the way yours are will make any future removal difficult !
        I originally did them as yours, then Ben suggested turning them round
        • kolmershlagjp
          • Dec 2015
          • 180
          hello
          can you tell me the brake cable you have to buy for a marina base roadster thank you?
          • martinclan56
            • Feb 2020
            • 486
            It's the standard Morris Marina. Loads on Ebay (uk).
            Cheers Robin
            • kolmershlagjp
              • Dec 2015
              • 180
              I bought a morris marina cable it was too small
              • martinclan56
                • Feb 2020
                • 486
                Yes - I thought about that. But, unless I slot the mounting holes there simply isn't enough room behind the brackets to fit a nut. As it is I had to shave about 1mm off the bolt heads. I have just enough room to get a spanner in as it stands.
                Cheers, Robin
                • martinclan56
                  • Feb 2020
                  • 486
                  Hmm - perhaps it was the wrong one. This is the one I have.
                    • 590
                    Hi Robin
                    I think your top damper brackets are the wrong way around. The build manual states the damper mounting holes should be closer to the outside as per the photo posted by dcunn above in post #4.
                    please double check.
                      Originally posted by jon_cox View Post
                      Hi Robin
                      My original suggestion to DCunn was fitting the bolt from the front to make changing the shock easier.
                      but jon you are mistaken DC top brackets are the wrong way round.
                      Top mount should be inboard following a natural angle from the bottom plate.
                      • martinclan56
                        • Feb 2020
                        • 486
                        Ha - interesting. That's why I fitted mine inboard. But I checked the manual and it does indeed indicate they should be the other way round. I don't suppose it makes a terrific amount of difference either way.
                        Cheers, Robin
                          • 590
                          but jon you are incorrect DC top brackets are the wrong way round.
                          Interesting debate. I actually agree with you Ben and I believe this is the way they were fitted when on the original Marina / Ital donor car.
                          I was merely pointing out that the Later Marlin Roadster build manual suggests that they are fitted as per DC's picture. Maybe, the fact that the lower damper mounting plates have been swapped from side to side to position the dampers rearward of the axle (which incidentally is the reason the handbrake cable is so close as per the original topic of this thread) has altered the geometry slightly prompting Marlin / YKC to suggest the change in orientation?
                          I love the world of home built cars....
                            • 2797
                            FWIW - and as far as my aged grey cells can remember, those brackets had large and smaller bolts so could only ever have been
                            fitted the way they were.......unimportant anyway in the overall build.
                              [ATTACH=CONFIG]12598[/ATTACH]
                              my build manual didn't mention that
