Good morning.
  • etypephil
    • Nov 2021
    • 8
    Good morning.
    I bought a Marlin Roadster
    a few weeks ago, having kicked the idea around for a long time, a few details on my Retrorides thread:
    With a mate, I had considered buying the company when it was for sale some time ago, but geography and the main asset being a diesel powered demonstrator put us off pursuing it beyong initial discussions.
    Two questions spring to mind; my Marlin is fitted with an ugly rollover hoop which seems to be welded in; if I remove this, is the chassis likely to flex unduly? What would be the options for seat belts and their mountings (it currently has inertia reel belts, the upper mounting being attached to the roll hoop)? That's really one question; #2 is:- How on earth does one upload an avatar / profile picture here?
    Edit, forget question #2; I've worked that one out.
    • 2445
    Re: Good morning.
    The screen is the roll bar on the Roadster and removing the one at the rear will not cause any problems as they were designed not to have one.
    Here is the solution Marlin came up with.
    Hope this helps.
    P.S. Welcome to the club.
    • martinclan56
      • Feb 2020
      • 474
      Re: Good morning.
      Welcome to the club. I am currently rebuilding DRL 152K. Or perhaps I should say building....
      Suggest you check for cracks in the bulkhead arround the pedal box. Older cars used to suffer badly with this problem.
      See my build thread!
      Cheers Robin
        • 2445
        Re: Good morning.
        Hi both
        This is what Marlin came up with as a solution to cracks in the bulkhead
        Hope this helps
          Re: Good morning.
          Follow the link in my forum signature for loads of info.
          • etypephil
            • Nov 2021
            • 8
            Re: Good morning.
            Thanks gentlemen, I have followed Steve's link to its conclusion, and will investigate the seat belt mountings and bulkhead when it gets light. From memory, I think that there is a bulkhead brace already. An interesting aside; the previous owner suffers weak legs, and added electric pump driven power assistance to the clutch and brakes. Something I have noticed when driving is a lack of steering self centring; is this a chassis design fault, or can the castor angle be adjusted (Marina suspension)?
            • martinclan56
              • Feb 2020
              • 474
              Re: Good morning.
              The Marina suspension is not really adjustable other than ride height. The major downside of its simple design.
              The only adjustment that Marlin suggest was the moving of the thick and thin packing washers on the top suspension arm.
              However some owners have modified the suspension to allow adjustment. The method seems to be to make the front tie bar adjustable and bin the torsion bar in favour of coil over dampers.
              I did think about it but decided to keep the standard setup at least to start with....
              Cheers Robin
                Re: Good morning.
                Lots of discussions on this over the years, best to look via the search facility on here. As Robin says though, it's really a feature of the design set up.
                  • 2445
                  Re: Good morning.
                  This is what Marlin suggested
                  Cheers Robin
                  • etypephil
                    • Nov 2021
                    • 8
                    Re: Good morning.
                    [ATTACH=CONFIG]12631[/ATTACH]
                    That looks useful; many thanks.
