Berlinetta sierra battery
This topic is closed.
  • terryrscott
    • Mar 2022
    • 132
    Can somebody please advise me what battery fits on the small shelf under the bonnet for a sierra based car please.
  • Kahawi
    • Jan 2018
    • 159
    Re: Berlinetta sierra battery
    Photos pretty much self-explanatory, I replaced the previous battery with a Bosch S4-004, same size, terminal locations etc. Just slightly too tall meant I had to grind away a little bit of the piano-hinge in the middle of the bonnet, but the shelf and holding clamp etc. fitted no problem.
    Mine is a Hunter, so I’m not sure the bonnet design is quite the same as a Berli, but I have the 2.3 litre DOHC Sierra/Scorpio/Galaxy/Transit engine and it cranks over fine with a battery of this spec.
      My Sierra based Berly has a self mounted on the front of the bulkhead/firewall, presentation of batteries here a la frog is different to the UK, it is a 54Ah unit, no other information visible, but the size is 21cm long x 17cm wide x 19cm tall, it is ample turning the engine over, a 2litre sohc pinto, in the depths of winter, slightly warmer than in the UK I suppose but not much. The battery of this size fills the tray, without mods, I suppose it might be possible to fit a larger unit. And also because the heater is at the back of the bulkhead shelf I don't think a battery could be mounted there.
      If you want a pic or two let me know!
      • terryrscott
        • Mar 2022
        • 132
        [ATTACH=CONFIG]12725[/ATTACH]
        thanks very much , the berlinetta with a pinto engine is a very different layout, but thanks for the response
        • terryrscott
          • Mar 2022
          • 132
          thanks for reply , thats helpful, i know what i am looking for now.
            the photo in pinto electronic ignition gives a good view of the battery, maybe dave can give you some battery details?
            • daveghunt
              • 71
              The battery I use is a Varta blue dynamic.
              544 402 044 3132 it's 44 Ah cold test current 440 amps.
              It' given me good performance even with a 40 year old starter motor
              and just fits on the tray under the heater pipe.
              Available space will depend on tray installation when built. One of the joys of kit cars.
              Hope this helps.
              Daveg
              • terryrscott
                • Mar 2022
                • 132
                thanks, i shall check that out
                • terryrscott
                  • Mar 2022
                  • 132
                  thanks dave, i shall check that info out on my car.
                  • terryrscott
                    • Mar 2022
                    • 132
                    thanks tony, i wonder if your car is LHD which could make the layout on the bulkhead/firewall differant, but its good gen , thanks very much
                      No, rhd -- i might be able to take a photo later, difficult to access at the moment! ;-)
                        Might seem like a stupid idea, why not measure the space and visit a motor factors with the dimensions. If they are any good then they can help you get one that fits in the space. if they can't/won't help don't use them again!
                          + ! Thats how i found mine!
                          • John_Mulvaney
                            • 139
                            In case you are unable to find a friendly local supplier:-
                            If you ignore the "enter reg" field on the Alpha Batteries website and select "Battery Type" you can scroll down through loads of differing car battery designs which give dimensions, layouts and terminal details - might be tedious and take some time to find something suitable but could save purchasing something that does not fit and at least you could check the dimensions of likely contenders! John
                            (I can recommend Alpha - I have been pleased with their service several times. I have no other association with the concern)
