B Series Engine Oil Cooler
  • martinclan56
    • Feb 2020
    • 485
    Has anyone fitted an oil cooler to their B series engined Roadster and if so was it beneficial?
    The engine I am fitting is tuned to stage 2 and I am wondering if an oil cooler may be worthwhile. Fairly cheap and easy at this stage of the build...
    Cheers Robin.
  • A_Hogg
    • 338
    Re: B Series Engine Oil Cooler
    Believe it was standard fit on MGB so why not !
      I'm not sure one is needed on a Roadster; whilst it was fitted to the MGB IIRC it wasn't fitted to the Marina TC.
      If you do decide to fit one make sure you also include a thermostatic valve so it only cuts in if/when actually needed.
      • martinclan56
        • Feb 2020
        • 485
        Thanks for the answers. My thinking behind the question was:
        The engine bay on the Roadster is pretty compact. Anything that helps dissipate heat must be a good thing.
        My engine is tuned = more heat. On the other hand so is the one in Lil Red Rooster and I guess you don't have overhating problems.
        And yes I believe it was fitted to the MGB as standard.
        Cheers Robin
        • boustrophedon
          • Apr 2019
          • 89
          My B-Series engine in a roadster had an oil cooler, but the pipes were all perished so I took it off, made absolutely no difference.
