Hi folks - I’ve a Cabrio built in ‘97 with a Ford 2lite Zetec engine which kept cutting out while pulling away from idling/standing - so I’ve sourced a replacement used auxiliary air flow valve being a Bosch part number 0280 140140. It seems to be a bit better but still not perfect so I just wondered if anyone else has had the same issue or has anyone found a better replacement/solution the now obsolete Bosch part?
