Hi, I have a 1996 registered Cabrio, 2litre pinto engine with Webber carb. Can anyone help please with part numbers for the throttle and clutch cables please. I am not sure if they are Sierra or Cortina parts. Many thanks. Phil Griffin.
Cabrio Hunter. Throttle/clutch cables
Tags: None
Re: Cabrio Hunter. Throttle/clutch cables
If you have the originals and they are simply worn out you should be able yo get new ones made by someone like Speedy Cables. May be easier than trying to track down old part numbers.
Cheers Robin
If it is the Sierra donor clutch and accelerator cables, and it probably is, the part number can be found here:
I purchased a replacement clutch cable in 2019 from eBay seller “carpartsinmotionâ€. I haven’t needed to fit it yet so can’t vouch for its quality but it looks good.
A search for “ford sierra clutch cable†gave 353 results many under £20. A search for “ford sierra accelerator cable†gave 65 results mostly under £20.
Hope this helps,
