Escort fuel gauge
    Re: Escort fuel gauge
    Well done. No more ‘Top Gear Rules’ on the Bicester run
      • 686
      Don't forget a filter mesh on the pickup to sieve out any crap from the tank.
        Good call, will do.
          Liberal amounts of JB Weld (that stuff is unbelievable) and a test tomorrow.
          Fingers crossed.
          Good call, will do.
            #20
            As always I have better ideas later and here we are version 2.
            First of all I was never happy with the Ford isolation for the sender as it just used a fibre washer between the connector and earth.
            So I took the one from the Smiths gauge and cut a thread on it pushed it through same hole and affixed with a bolt, much better
            Next was the rethink, as you can see from the picture below, I decided to JB Weld the Smiths sender to the original Ford pipe and then cut off the Smiths float arm and solder the original Ford float arm to it. Basically now, it is the Ford unit with the Smiths sender carefully grafted onto it.
            I hope this makes sense, now to test.
            And a close up of the graft
              #21
              Well my rudimentary dip stick (a stick with marks on it) says 1/4 full as does the fuel gauge.
              Yippee
              That's that one jobbed jobbed.
              ​Adrian
                • 2796
                #22
                Bet you needed your glasses for that job, well done.
                  #23
                  Thank god for vary focals
                    • 2796
                    #24
                    Agreed !
                    • A_Hogg
                      • 338
                      #25
                      It's a thumbs up from me!
                        #26
                        Thankyou, I'm no engineer and just like to workout things.
                        Keeps my 67 year old brain ticking over.
                          I need to get cracking on a few jobs on mine but I’m suffering from post Covid dug at the moment. Well done, what’s next on it?
                            #28
                            Find out why the Hill Assist turns itself off when I switch the lights on, on my Alfa 159
                            Oh, you mean the Marlin, nothing except drive it.
