Following a recent MOT pass I had a good drive in my Marlin up to a family meeting in Somerset. Nice to see sunshine and dry roads.
Hunter exercise
Tags: None
Yes it is Geoff! Feeds both an oil cooler and an extra rad mounted under the front apron. Extra rad is plumbed in between the main rad outlet and the water pump inlet.
I can’t find anything by searching on the forum but maybe using the wrong search criteria? However I did write an article for Pitstop about it with photos. Would have been a good few years ago now though! Time flies when you’re having fun, as they say! Peter.
P.S. I have a note that I collected the new extra rad that I had made on 20/4/2014 so the article in Pitstop would be around that time. Peter.
Thanks Geoff. Thats the one! Its more comprehensive than I remember and hopefully will help other MOC members! It still works well and after recently replacing a failed (open) thermostat the temp rarely goes above the opening temp on the gauge.Originally posted by ggrum View PostHello Peter,
Your article entitled 'Cooling Upgrade for V8 Hunter' was featured in Pitstop issue 193 April/May 2016. I remember it now.
GeoffLast edited by greyV8pete; 12-04-23, 09:01 PM.
