Marina based Roadster - lower suspension arm angle.
  • martinclan56
    • Feb 2020
    • 486
    Am I correct in saying that the lower suspension arm is roughly horizontal under normal conditions?
    I don't have an engine in yet or wheels on the car so trying to get some idea.
    I have the static measurements from the building instuctions, but would just like some idea of where it should sit when on the road!
    Cheers, Robin
  • A_Hogg
    • 338
    Think you'll find that the outer end of the arm is lower than the inner .
      • 930
      Hope this helps visualize it. Note though that mine is lower than most at the front which makes the lower arms flatter than normal. If you go to the trouble of calculating the roll centre it should be the same height at the front as the centre of the diff.
      • rhysnolan
        • Jul 2023
        • 139
        I can measure height difference later today, but surely depends on whether the car is going to be low, or high as a trials car would be?
        • martinclan56
          • Feb 2020
          • 486
          Thanks all. I was just trying to get some idea. I have adjustable tie rods and I am just trying to set the length so that the torsion bar is not under any lateral strain when the suspension is at normal height.
          Once that is OK I can think about adjusting it for real to try and get the elusive steering self centering....
          • rhysnolan
            • Jul 2023
            • 139
            Do you still need this info? Mine is 45 mm higher at the inboard end when sitting on it's wheels . I could do it unloaded if you want?
            • martinclan56
              • Feb 2020
              • 486
              Thanks. That's usefull and about what I guessed (2"). I was just trying to check the front suspension was roughly correct before I fitted the reaction levers to the end of the torsion bars. They are a bit of a b8gger to fit and I was trying to avoid having to adjust it again once the engine was in.
              Unloaded actually isn't that usefull as the dampers limit the "droop" anyway.
