Berlinetta tyre pressures
  • marlineer
    • Jun 2024
    • 24
    Hi, can anyone recommend the correct tyre pressures for a Cortina based Berlinetta with a 2L Ford Pinto engine?
    Thanks.
  • Kahawi
    • Jan 2018
    • 159
    Somewhere back in the past I linked a web-based pressure calculator on here that took tyre size, rating and weight of vehicle.
    For my Sierra-based Hunter the calcs came out at 13psi all round. Personally I think that’s a bit too soft (frightened the tyre would come off the rim on a harsh corner) but somewhere below 20psi seems to give the softest ride for touring, given the state of our roads today.
    • MOC Chair
      • Dec 2022
      • 225
      I run a Sierra based Berlinetta with 185/80 tyres with pressures of 20 psi front and 22 psi rear. With wider tyres you might find that you will be happier with pressures slightly lower. It is a matter of personal preference.
      • marlineer
        • Jun 2024
        • 24
        Thanks for the posts.
