crankshaft pully nut.
  • yousay54
    • Aug 2018
    • 90
    Hi Can anyone tell me the crankshaft pully nut size on the 1275 marina ital engine, not easy to get to measure, thanks.
  • A_Hogg
    • 338
    Believe I've used a 3/4 Whitworth socket on that one as it was all I'd got . Equates to 33mm or 1 5/16 AF
    • yousay54
      • Aug 2018
      • 90
      Thanks for tnfo will just use adjustable spanner only need to set tappets after new head gasket.
      • Ye Ol Ripper
        • May 2016
        • 298
        If you put the car in 4th gear and push the car, you won't need to turn the nut on the crankshaft
        • yousay54
          • Aug 2018
          • 90
          Thanks Ye Ol Ripper i am half mile down the road and not set a tappet yet, That is a joke by the way? Am told Halfords do a socket at £10.35p, have to have a look in my money box?
          • Ye Ol Ripper
            • May 2016
            • 298
            My recomended method is preferable to using a socket, which i do have in my toolkit. As it
            Its much quicker & to turn the crank you will probably be continuously going under the car and then getting up to them adjust the valve clearances. Its not easy seeing when a valve is fully open to then adjust the corresponding closed valve whilst turning that socket. With my method using 4th gear you can though.
              • 1648
              Maybe obvious but remove the plugs first when turning the engine over by hand for checks!
