Clutch master cylinder marina
  • wilkywoo
    • Dec 2025
    • 29
    My master cylinder is losing fluid, its old Lockheed martin one.
    do I rebuild it or I read on here series 3 land rover ones fit?
  • A_Hogg
    • 338
    Fairly common swap among the TVR community as they are readily available and you're not paying the TVR tax! Just be aware that the Land rover ones we use on TVR's have a metric thread for the fluid pipe and not the original UNF. Can't say if this will be same in your case.
    • wilkywoo
      • Dec 2025
      • 29
      Thanks, yeah apparently you can get the adaptor.
      • martinclan56
        • Feb 2020
        • 484
        I rebuilt mine with new seals. Ebay NOS as I remember. It hadn't seen any use for 30+ years so well knackered. Now works fine.
        • A_Hogg
          • 338
          Original part number for the Clutch master cylinder kit was SSB 1238 and SSB 619 for the slave cylinder seals
          • wilkywoo
            • Dec 2025
            • 29
            I took mine apart and the whole bore looks like it was found with tutankhamen.
            • wilkywoo
              • Dec 2025
              • 29
              Just for heads up part number STC500100 series 3 land rover master cylinder bolts straight in, just had to swap the clutch pedal arm. The pipe bolted straight in without the adapter.
              I now have a wonderful clutch pedal.
              • martinclan56
                • Feb 2020
                • 484
                Thanks for the info. Useful to know for the next time...
                • A_Hogg
                  • 338
                  Good news and useful info
