Clutch slave rod shortening
  • wilkywoo
    • Dec 2025
    • 29
    Another day another question.
    Fitted new slave cylindecylinder successfully but the pedal stops 1.5 inches off the floor, clutch arm when pedal is down is against the bell housing.
    Can I just shorten the slave rod a little or am I risking the piston coming out or anything else?
    Clutch feels absolutely fine driving just unnerving it won't go to the floor and im worried I will push it too hard and pop seals ect.
  • copperleaves11
    • 328
    If It's comfortable to use you could always put a stop under the pedal.
    • wilkywoo
      • Dec 2025
      • 29
      Yea thought that but I worry as the bite point us right at the top
