What Carb is ran on the Twin cam .I run A Wabber DCNF & it Gasses up at the wrong time on trials i.e could not get away on Blue hills 2 on Lands end
Carb on Fiat Twin Cam
Re: Carb on Fiat Twin Cam
It depends on the engine and the age.
My 1984 2 ltr uses a Weber ADF twin choke downdraught carb.
The choices range from Weber DMS & ADF to various versions of the Solex C34.
The engine can be run on single or twin sidedraught Webers & Dellortos providing you have the right manifold. These are often available on Ebay.
Check the slow running jet - if the tiny rubber o-ring is damaged, the mixture will be messed up. My auto choke was being jammed closed by the screw that holds the throttle open when cold. It was not sat on the cam and slid down the side jamming it open. VERY rich running. Simply bent the lever to fix.
Pete
