Marina Clutch Slave Cylinder Rod
  • email
    • 25
    Hi there, posted some problems with my Marlin back in December and have since found the weather and motivation to drop the box off. It would seem the route of my problems was that the actuator arm which moves the release bearing has come unlocated from its ball joint, hence the sparks, loss of clutch and extended movement of the clutch slave cylinder, lending to the slave cylinders failure.
    So... I have replaced the slave, with a new one (thanks DMS Classics - ebay) put the gear box on etc and now CANNOT FIND THE SLAVE PIN....
    Does anyone have one, or know where I can get one, I also need to replace the flexible hosing between the master and clutch slave, which is 3/16" ID Lockheed tube, again - any ideas where I can get this.
    Your help would be really appreciated.
    Thanks
    Re: Marina Clutch Slave Cylinder Rod
    Hi Brian
    Try Powertrack for the hose.Didn't the new slave cylinder come with the pushrod? they certainly used to be supplied when you purchased a sevice kit, so that might be one way of obtaining [Powertrack again?] Looks like I was correct in my diagnosis after all !
      Me Again
      Clutch hose on e bay item 280217286323
      • email
        • 25
        brill, on the the hose, I have asked for a buy now. The slave did not come with a pin, it was new in box so I guess the girling one never did, would still appreciate any help.
        • email
          • 25
          Panic over, I have found the rod, hiding under the wiper motor, where else would it be ?
            Funny how they find their way to the most obscure locations! Hope you're going to become one of the membership.
            • email
              • 25
              yes I fully intended to , applied online, printed it out and then lost it before the clutch issues. Will re-do it and post for the weekend :0) appreciate all the help the forum has given me alone.
