Exhaust leak
  • grahamc304
    • 6
    Exhaust leak
    I'm having a problem sealing my exhaust where it joins onto the manifold. It's a 1275 A series engine with the manifold just under the carb. Should there be any sort of gasket or saling ring between the two. I've tried all sorts of pastes but I can't get a good reliable seal.
    Does anyone have any suggestions?
  • donsayers
    • 282
    Re: Exhaust leak
    In my youth when I had a Marina I used Holts exhaust sealant compound and a ring of scrunched up aluminium foil. It worked a treat.
    If you can, brace the exhaust to the engine or gear box with a stay, the movement of the engine has a habit if snapping the cast iron exhaust manifold, where the joining clamp fits.
    • keith_h
      • 549
      Re: Exhaust leak
      A few years back I fitted a small length of stainless flexible to mine to take up the movement (there was someone selling them at Stoneleigh but I can't remember their name)
      • trevor_ford
        • 213
        Re: Exhaust leak
        Gotta agree with Don. When I had the 1275 fitted it had a bracket attached between the downpipe and the bellhousing. I seem to remember that the exhaust had to be attached securely to the manifold before the rest was attached to the car or it was almost impossible to get a good seal. Liberal amounts of Gun Gum were used too.
        • grahamc304
          • 6
          Re: Exhaust leak
          Thanks guys, I had a go at it this morning and touch would, it seems a lot better now
