Glass Fibre Starring
  • csjcarolyn
    • 157
    I am starting the preparation for a re spray on my Berlinetta and have noticed a couple of areas which are "starred". I heard years ago there was a special repair procedure or the paint drops off. Can anyone help with details of this procedure?
    Many thanks Roger Johnson
    Re: Glass Fibre Starring
    Roger
    The 'starring' you refer to is generally in the gel coat of the glassfibre.It can be repaired quite successfully by using a gel coat repair kit which you can obtain from dinghy chandlers/boat builders.
      Believe me this is the best and lasts - CAPTAIN TOLLYS CREEPING CRACK CURE
      • KitCarGirl
        • 720
        Does this work for builders' bums?
          Why, have you got one?
            It works on hair line cracks not hairy arse cracks.
            • KitCarGirl
              • 720
              I certainly haven't got a builder's bum. At least I don't think I have.
              Ben, on the other hand...........and before you ask, he has been known to shower al fresco. I have a picture to prove it. The exhibitionist!
                Who is Al Fresco ?
                  He is the one who wouldnt pick up the soap:-|
                    Back in the barrel for him then :~(
