Hi to all. I have a 1993 Marlin Roadster based on a Marina/Ital Donor, running 1400cc A Series Minisport Engine. It has been off the road for a year...
I need to replace the front bushes on the end of the Tie Rods (underneath either side of the numberplate at the front) sorry if Tie Rods is incorrect. Any ideas where to get some ? I have checked superflex but they only seem to list Morris Minor ones. I also need to bleed down the clutch at i have replaced the slave, refitted the gearbox but cannot get pressure on the pedal, any ideas, the gearbox was removed as the pivot arm had disclocated off the ball joint so the clutch would not engage (simple now I took it out)
I have since snapped the manifold off refitting the exhaust (now replaced) so just need to sort the bushes , stop the down pipe from blowing at the manifold (x2) and get the bushes replaced as well as get pressure on the pedal , all this would make me a very happy man.
Would appreciate your assistance
Thanks
Thanks
