There seems to be a lot of play in my steering column section between the wheel and the rubber joint. Presumably this is just wear, but it does make it a bit uncomfortable on bumpy roads making the steering wheel jump about.
Does the standard Marina column fit in here or does it have to be shortened? In the absence of finding a new part it is possible to rectify the play and if so does the column have to be removed?
Many thanks in advance.
