Handbrake Compensator lever
    • 2444
    Hi does anyone have lying around a complete Handbrake Compensator lever for a Morris Marina.
    Obviously willing to pay for said item.
    Re: Handbrake Compensator lever
    Which parts do you actually need? I am not sure what you are calling a compensator?
    I have the remains of a Marina back axle and old handbrake cable that I have replaced.
      • 2444
      Sreve the picture on the top right is the section I need. Hope that explains it, the picture is not that good.
        • 2444
        Sorry typing problems Steve.
          I have got those bits though the rubber washers are showing distinct signs of age.
          Can send them off to you. Email me at [email protected] with your address and make me an offer.
          Incidentally when I fitted the Sprint axle I fitted a new Ital handbrake cable that does not use the mechanism shown. It has a 4" long rectangular steel bracket and thicker inner cable and outer sleeve. It only needs the outer being occasionally located with a p clip and is not attached to the axle.
            • 2444
            Have emailed you. Yep the fitment you are talking about, according to the Marina parts list I have, is for a set without automatic adjustment. Many thaks anyway. Adrian
            • pearwood
              • 36
              adrian if it helps ive got leyland micro fich on marinas. the compensating bush part number is fam 320 this is for marinas 1971 to oct 1975-on. any other part numbers you need just ask and i will gladly help. thanks bob
                Parts in the post
                  • 2444
                  Bob thanks for that. Parts seem to be used on MGB's and Rover SDi's as well. Steve Many thanks your a life saver. Don't forget to email the cost of the postage and whether you are ok with a Cheque for the full amount. Cheers guys. Adrian
