Hi, Has anyone got a Marina 1.3 pre-engaged starter they don't won't, I could really do with one. Adrian
Marina 1.3 Pre-engaged Starter
Re: Marina 1.3 Pre-engaged Starter
Hiya, I have had a look at all these and they are either for the 1.8 or 1.7 engine , unfortunately not the 1.3. If anyone has a 1.3 pre-engaged motor I would be very interested in buying it off them. Adrian
I bought one from a local accessory shop - they seemed to have no problems getting it and I would imagine worst case most places could get your rebuilt - perhaps a bit more than £20, but I seem to remember it being about £35 exchange. Add postage to a second hand one and I am not sure you will save much.
Adrian - I am actually in Bristol. The one that I used at the time was called Bitz-Z-Cars which have sadly now closed down, but there are others around here like Brights Auto Center who I am sure could get one - but I would have thought most "traditional" car accessory shops would have a local contact that could at least get yours reconditioned.
When I sheared off the battery connection stud on my starter I took it down to Lucas in Brighton and found a man with a handful of spare parts who repaired it for me FOC.
Have you a Lucas office near you, perhaps its a national Customer service policy.MOC member since 05/97
Hi everyone, thanks for your replies and I will be following up the local accessory idea and I think we have a lucas office in Hemel, so will try that as well. I will keep you informed. Adrian
Hiya, If anyone has got a 1.3 with a pre-engaged starter motor can you give me the numbers on the side as the part number in the book cannot be found by anyone. The numbers I would like are on the starter motor itself not the ones on the solonoid. Many thanks. Adrian
hi adrian
found some lucas part numbers for starter motors,
austin/morris ital 1.3 cr 5" pcd 9 or 10 tooth inertia 1980 to 1984. part number LRS 127
austin/morris marina 1.3 cr 5" pcd 2 holes 9 or 10 tooth inertia 1971 to 1978 part number LRS 101.
THESE ARE LUCAS B90 EXCHANGE UNITS.
any other info i will galdly help. bob
