Hi, this is probably one of the simpler questions asked on this forum. My LWB Roadster, 1.7 Ital lump etc has sprung a slow drip from the radiator drain plug. I don't know the origen of the Rad'! I need a new washer; simples! But I don't quite know what to get. My normally excellent and reliable Motor Factor in Peterborough can't help so can anyone suggest the options? I.e.: can I chop the center out of a domestic tap washer or is there a supplier of the correct items out there. Last resort would, I supose, be to blank off the tap and drain from the bottom hose. The actual tap is plastic and the current washer appears to be rubber if that helps.
Thanks in advance for your thoughts.
