Wanted: Front Offside caliper bracket
    I am looking at different ideas for rear disc brakes on a Marina axle.
    What I would like to play with is a front offside caliper bracket, a nearside will do but I prefer an off side. If you have not got one by itself, perhaps you will have one bolted to a front suspension leg.
    Contact me at stevejgreen(at)btopenworld.com
    • 708
    Re: Wanted: Front Offside caliper bracket
    I wish I could help...but I'm looking for a pair...! I'm thinking of following your Clio-path but I'm slightly reluctant to butcher the existing brackets (though I know a 3mm washer would restore the status quo). Sods law was the only uprights and hubs I've seen on flea-bay for ages were from a drum-braked 1.3...but I bought them anyway...and was pleasantly surprised to see someone had fitted longer 7/16 studs...!
      Jez, go ahead and butcher yours.
      The bit you are going to remove does not have any thread in it so it serves little more purpose than a washer anyway.
      I tapped mine out to the larger M12 1.25 thread rather than create shoulder bolts. To revert back to Marina I would have to drill the Marina caliper holes from 7/16" to 12mm, again not a significant change.
      Someone out there must have a spare bracket or two. They are the sort of thing that will sit on the shelf for ever or get thrown away as they have no other use.
      • CABRIOBOB
        • 478
        Jez,Please contact me as details are in pitstop as I have several sets of the fixing plates.
          Bob,
          Perhaps you missed my initial request.
          If, as you say, you have several sets, could you not supply a pair to both Jez and myself, rather than just a single one that I originally requested?
          I would be happy to cover any reasonable postage costs etc.
          Contact details as above, stevejgreen(at)btopenworld.com
          • CABRIOBOB
            • 478
            Jez, The brackets have been posted to you today.
            • CosworthCabrioLee
              • 924
              Hi Jez are you doing a rear disc conversion ? worth doing if you are.
                If you convert the rear brakes to disc and hydraulic caliper what do you do for a handbrake?
                  When I first heard about rear hydraulic disc brakes I asked the same question.
                  In simple terms almost all rear calipers are fitted with a secondary mechanical piston inside the bore of the caliper. This is actuated by a lever pulled by the handbrake cable.
                  Do a search on eBay for a Sierra Rear Caliper and look at the pictures. You will see a torsion spring that retracts this secondary piston and lever.
                    • 708
                    Thanks Bob...I'll give you a call to arrange some beer tokens..!
                    Lee - no plans for rear discs yet. Just fitting a Sprint axle and fancy beefing up the front brakes to overcome any potential for rear lock-up issues...once that's done I might investigate a rear disc setup.
                      I now have the parts I need from colleagues on the Fastmarina forum.
                      The bracket has enabled me to refine my design though not appropriate for a Marina, ideal for a Sprint axle.
                      Thanks to those who have helped.
                        Jez, have you thought about using one of the ford valves to prevent rear lockup - they were fitted to lotus elans and all sorts of escorts too. Basically its a tube with a ball bearing in and as the weight transfers to the front the ball rolls forward into a shallow funnel reducing the pressure at the rear. I happen to have one sitting around if you want to try it? :-)
                        Have attached a picture of one from a mk5 escort on ebay (ford brake valve) which is a twin unit - you would only need one it the main rear line.
