Radiator drain cock
  • keith_h
    • 549
    Radiator drain cock
    Has anyone fitted a drain cock to the bottom of a radiator - is there enough meat to take a tap or does it have to be brazed
    (Escort van radiator)
    Re: Radiator drain cock
    Assuming the headers are metal(some are plastic) you need to have a threaded boss soldered into the bottom header. On triumph rads they used to have a little tap or plug at the bottom.
      • 905
      Hi Keith, My local rad repairer (Victoria, Cornwall) would do this while you wait! It is best to get a boss braised to the bottom of the rad. I'm sure there will be a radiator repair firm near you.
      • keith_h
        • 549
        Good point Dane - thanks. I suppose I should have thought it through. If they are going to save pennies by not putting drain taps on, they are not going to use material thick enough to tap
