Wiper Motor
  • bryannewell
    • 331
    Wiper Motor
    Hi folks
    My Roadster wipers do not cover the whole screen
    The gear wheel is 120deg presumably a 130deg would help?
    Not sure what its from so see attached pics
    Anyone got one to sell please?
    Email at bryannewell715(at)msn.com if prefered
    Bryan
    Re: Wiper Motor
    First place to look is http://www.s-v-c.co.uk/prod_wipers.html They used to stock all sorts of gears etc.
    Take care with the arc that the wipers travel trough, some arms may get too close to bodywork or bonnet for comfort depending on instalation.
    • terryreed1664
      • 257
      Re: Wiper Motor
      Hi Bryan,
      I converted my Berlinetta to this sort of wipers system, I used the MGB wiper motor and Land rover Defender wheel boxes. This gave great results. I'm not sure this will work on your Roadster, but it may with smaller arms and blades.
      Terry
        Re: Wiper Motor
        Marina wheel boxes are not the best...SVC do 32 tooth versions which give you better sweep with that motor (marina are 38 iirc). Also check the overall setup as loose wheelboxes & badly fitting/poorly greased cable/bundy tubes can lose you valuable movement.
          Re: Wiper Motor
          Have a look at J&L Spares Export Ltd looks like it may be helpful.
          jlspares.com/electrical spares htl
            Re: Wiper Motor
            Austin Allegro has 32 tooth box and is dimensionally correct, i.e length of spindle. I fitted these to my Roadster .
            • bryannewell
              • 331
              Re: Wiper Motor
              Hi Gents
              Thanks all for your replies
              I'll have to get behind dash to see what wheelboxes I have and go from there
              Many thanks
              Bryan
              • bryannewell
                • 331
                Re: Wiper Motor
                Wheel boxes now out,turns out they are 40 tooth!!
                No wonder the sweep is rubbish!
                Anyone know what they might be from?
                Bundy tube US so have made up some more so that is sorted,just need to get some 32 tooth wheel boxes.
                probably svc the place to try?
                Bryan
                • bryannewell
                  • 331
                  Re: Wiper Motor
                  Terry
                  Some defender wheelboxes on Fleabay,what length of spindle? as they look too long in photo!
                  Are splines a common size or would I be looking at different wiper arms as well if I go down that route?
                  Bryan
                  • bryannewell
                    • 331
                    Re: Wiper Motor
                    New 32 tooth wheelboxes soured from SVC,now fitted and much improved,may fit a 130geg gear wheel later to make things perfect!!
                    Many thanks for all youe help
                    Bryan
