marlin (escort van) petrol sender
  • edward_chambers_3
    • 1
    could anybody tell me where I can get hold of a petrol sender unit for my Marlin.The tank is off a ford escort van pre 1984 thanks Ted
    Re: marlin (escort van) petrol sender
    You are right it\'s an Escort van tank.
    Normally cars are fitted with the correct Ford Escort sender but this is known to give bad readings.
    Someone, once grafted a Marina sender onto a Ford. It will work but the float arm will need bending to suit the depth of the Ford tank.
      You can get a \'Universal\' one from the likes of Europa .I found that together with a Smiths fuel guage I got pretty accurate readings.
