SPA digital speedo
  • derekkitchener
    • 33
    SPA digital speedo
    my 1987 sportster has the SPA fitted, the sensor under the car and the 2 wires have parted flush with the sensor, SPA have no spares over 10 years old, nor has RS components, please any ideas. I am joing the club.
    • 905
    Re: SPA digital speedo
    Try http://www.etbinstruments.com . ETB are experts for firms such as VDO but they do carry stock of universal senders. I get my VDO stuff from them.
    The sender is most probably a Hall Effect semiconductor. I recently repaired a large baler that uses these items all over the place to detect movement of parts of the machine. These sensors are available, I'm surprised that RS couldn't provide one. Anyway, I reckon a quick word witrh ETB will sort you out. Good luck.
      • 905
      Hi again. If your speedo requires a Hall Effect device then RS do supply quite a few different types. As an example, and I don't know whether this one is compatible with your instrument, have a look at the Honeywell SR3C-A1. It has the correct voltage range and may be your answer! Good hunting.
      • tim hawkesworth
        • 178
        Hi Derek,
        Are you sure your car is that old. Sportsters were not introduced until 1996/7. That info may help you in your search.
        Have you considered joining Moc ? Join now and your sub will get you benefits thro' to Jan 2013, for just £17-50
        • derekkitchener
          • 33
          SPA do a hall effect spare but it is not compatible with the older model
